The following command enables MAC locking both globally for the device (stack) and at the port level for ports 2:1 through 2: 5:
Slot-1 Stack.1 # enable mac-locking
Slot-1 Stack.2 # enable mac-locking ports 2:1-2:5
The following command lines enable port 2:1 for a maximum of 3 static MAC address entries. This is followed by four static MAC address creation entries. The fourth entry fails because the maximum allowed has been set to 3.
* Slot-1 Stack.3 # configure mac-locking ports 2:1 static limit-learning 3 * Slot-1 Stack.4 # configure mac-locking ports 2:1 static add station 00:22:33:44:55:66 * Slot-1 Stack.5 # configure mac-locking ports 2:1 static add station 00:22:33:44:55:77 * Slot-1 Stack.6 # configure mac-locking ports 2:1 static add station 00:22:33:44:55:88 * Slot-1 Stack.7 # configure mac-locking ports 2:1 static add station 00:22:33:44:55:99 Error: Station 00:22:33:44:55:99 cannot be added as maximum static limit of 3 is already reached on port 2:1. * Slot-1 Stack.10 # show mac-locking stations static ports 2:1 Port MAC Address Status State Aging ----- ----------------- -------- ------------- ----- 2:1 00:22:33:44:55:66 active static false 2:1 00:22:33:44:55:77 active static false 2:1 00:22:33:44:55:88 active static false Total for specified ports: 3 Static: 3 First-Arrival: 0 * Slot-1 Stack.11 #
* Slot-1 Stack.12 # configure mac-locking ports 2:2-2:5 first-arrival limit-learning 15
* Slot-1 Stack.13 # configure mac-locking ports 2:2-2:5 trap on
* Slot-1 Stack.14 # show mac-locking ports 2:1-2:5
MAC locking is globally enabled.
Port MAC Trap Log FA Limit Link Max Max Last Violating
Lock Thr|Viol Thr|Viol Aging Action Down Stc FA MAC Address
Stat Cfg|Stat Action
2:1 ena off|off off|off dis ena|ena clear 3 600 00:00:00:00:00:00
2:2 ena off|on off|off dis ena|ena clear 64 15 00:00:00:00:00:00
2:3 ena off|on off|off dis ena|ena clear 64 15 00:00:00:00:00:00
2:4 ena off|on off|off dis ena|ena clear 64 15 00:00:00:00:00:00
2:5 ena off|on off|off dis ena|ena clear 64 15 00:00:00:00:00:00
Legend:
Stat - Status Thr|Viol - Threshold | Violation
Max Stc - Max Static Count Max FA - Max First-Arrival Count
dis - Disabled ena - Enabled
retain - Retain MACs clear - Clear MACs
Limit Action Cfg - If port should be disabled when learnt limit is exceeded
dis - Port to be disabled when learn limit is exceeded
ena - Port to remain enabled when learn limit is exceeded
Limit Action Stat - Port status on exceeding learn limit
* Slot-1 Stack.15 #
